Fusion Manufacture
How to use multiple depths with contour cut
1 REPLY 1
feldman_itai01
103 Views, 1 Reply
Hi, whenever I use the multiple depths feature and stimulate a toolpath the cuts start at the bottom of the material and make multiple passes as it is going up. I want the tool to gradually go lower and lower with every cut not vice versa. Does anyone know how to fix this?
1 REPLY 1
It sounds to me that you have Simulation running in reverse. There's a slider below the Play/Pause button, make sure it's to the right
Seth Madore
Technology Administrators
