Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
How to use multiple depths with contour cut
1 REPLY 1
feldman_itai01
113 Views, 1 Reply
Hi, whenever I use the multiple depths feature and stimulate a toolpath the cuts start at the bottom of the material and make multiple passes as it is going up. I want the tool to gradually go lower and lower with every cut not vice versa. Does anyone know how to fix this?
1 REPLY 1
It sounds to me that you have Simulation running in reverse. There's a slider below the Play/Pause button, make sure it's to the right
Seth Madore
