Hi, whenever I use the multiple depths feature and stimulate a toolpath the cuts start at the bottom of the material and make multiple passes as it is going up. I want the tool to gradually go lower and lower with every cut not vice versa. Does anyone know how to fix this?
It sounds to me that you have Simulation running in reverse. There's a slider below the Play/Pause button, make sure it's to the right
