Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
How to make the Tool come straight down.
4 REPLIES 4
durrelwilley1
229 Views, 4 Replies
I'm trying to get this tool to come straight down, because this will be cut out of a sheet of material, and I'm trying to save material, any help would be appreciated.FusionTest1.PNG
4 REPLIES 4
seth.madore
in reply to: durrelwilley1
Turn off your Lead-In/Out settings, or set them to zero. This can only be done if you're using "Computer" compensation
Seth Madore
That worked, it took a while to find where to turn them off, not in a spot that is expected
where did you expect them to be?
Please click "Accept Solution" if what I wrote solved your issue!
Under the Modify Tab
