How to make the Tool come straight down.
durrelwilley1
durrelwilley1
I'm trying to get this tool to come straight down, because this will be cut out of a sheet of material, and I'm trying to save material, any help would be appreciated.FusionTest1.PNG
seth.madore
Turn off your Lead-In/Out settings, or set them to zero. This can only be done if you're using "Computer" compensation
Seth Madore
durrelwilley1
That worked, it took a while to find where to turn them off, not in a spot that is expected
programming2C78B
where did you expect them to be?
Please click "Accept Solution" if what I wrote solved your issue!
durrelwilley1
Under the Modify Tab
