I'm trying to get this tool to come straight down, because this will be cut out of a sheet of material, and I'm trying to save material, any help would be appreciated.
Solved by seth.madore. Go to Solution.
Turn off your Lead-In/Out settings, or set them to zero. This can only be done if you're using "Computer" compensation
That worked, it took a while to find where to turn them off, not in a spot that is expected
where did you expect them to be?
