Fusion Manufacture
Ghost image from previous Manufacture profile
11 REPLIES 11
Message 1 of 12
w.wilcoxALB5Z
506 Views, 11 Replies
When I use a machine more than once ( in a new project)in the manufacturing workspace, I am getting a part from another completely separate manufacture workspace showing in the current workspace.Fusion360Issue.jpg
11 REPLIES 11
Message 2 of 12
seth.madore
in reply to: w.wilcoxALB5Z
This has popped up occasionally, and it's been somewhat elusive in tracking down the source of this error. For you, does it persist thru a Fusion restart?
Seth Madore
Message 3 of 12
w.wilcoxALB5Z
in reply to: seth.madore
Yes it does persist thru Fusion restart and a system reboot, restart.
Message 4 of 12
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/f3z file in your reply.
Seth Madore
Message 5 of 12
w.wilcoxALB5Z
Hope this helps
Message 6 of 12
seth.madore
What version of Fusion are you on? Current version should be 2.0.16985
Seth Madore
Message 7 of 12
w.wilcoxALB5Z
Fusion 360 2.0.16985 x86_64.
Hope this helps. It has persisted thru a number Updates.
Message 8 of 12
seth.madore
-EDIT- retracted everything I posted here..
When this is happening to you, do you have both files open at the same time?
Seth Madore
Message 9 of 12
seth.madore
We think we've discovered the source of the issue. Somehow, when you created your Machine Configuration, you managed to include elements of one design in its structure. I reckon that if you insert that Machine Config into ANY file, you're going to end up with the same result.
The solution is to create a new Machine Config and have only settings, no model.
Seth Madore
Message 10 of 12
jscott6SWZG
Aha.  Think this might be one of my problems.  Now that I think about I have a couple of machine models, and it seems to corolate,
Message 11 of 12
w.wilcoxALB5Z
I will give it a try. Any reason for it to do that? or is it a bug?
Message 12 of 12
seth.madore
It's not a bug on our side, it's how you've defined your machine configuration.
Seth Madore
