When I use a machine more than once ( in a new project)in the manufacturing workspace, I am getting a part from another completely separate manufacture workspace showing in the current workspace.
This has popped up occasionally, and it's been somewhat elusive in tracking down the source of this error. For you, does it persist thru a Fusion restart?
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/f3z file in your reply.
What version of Fusion are you on? Current version should be 2.0.16985
Fusion 360 2.0.16985 x86_64.
Hope this helps. It has persisted thru a number Updates.
-EDIT- retracted everything I posted here..
When this is happening to you, do you have both files open at the same time?
We think we've discovered the source of the issue. Somehow, when you created your Machine Configuration, you managed to include elements of one design in its structure. I reckon that if you insert that Machine Config into ANY file, you're going to end up with the same result.
The solution is to create a new Machine Config and have only settings, no model.
Aha. Think this might be one of my problems. Now that I think about I have a couple of machine models, and it seems to corolate,
It's not a bug on our side, it's how you've defined your machine configuration.
