Fusion Manufacture
September 2023 Post Processor and Machine Simulation What's New
0 REPLIES 0
Message 1 of 1
andrea.amilo
1178 Views, 0 Replies
Post Processor and Machine Simulation What’s New
Looking for the latest post processors and machines updates? Look no further!
We are continually working
hard to bring you updates and improvements to the many open-source Post Processors and Machines we offer for free, but those updates often get lost in the shuffle of other enhancements or big feature releases. This post aims to update you on newly added or improved post processors and machines, so you can stay up to date on what you use today or look for news so you can get the most out of Fusion 360.
This post will get refreshed with notable updates as they’re released, and you can click each hyperlink to go to the mentioned post. As always, you can find the latest in our post processor offering on the Online Post Library where you can search by vendor, type, or name, and see any recent changes to each post processor.
MAIN CONTENTS
  1. New Post Processors
  2. Improved Processors
  3. New Machines
  4. Improved Machines
  5. New Workholdings
  6. Tool Applications
  7. Post Processor Engine
Milling Post Processors
Machine Tool Camp
Added Machine Tool Camp post processor.
Siemens Sinumerik ONE
Added Siemens Sinumerik ONE mill post processor.
Siemens 828
Added Siemens 828 mill post processor.
Additive Post Processors
BIQU range of printers
Added new post processor for BIQU fff printers.
2. Improved Post Processors
We are always working to keep post processors up to date with new technologies. This is a summary of the main improvements made to post processors already in the library.
Denford
Changed retract to do XY after Z retract and made all initial moves be rapid rather than high feed moves.
ProtoTRAK
Made G2 and G3 codes be output on every line rather than be modal and made every circular line contain I, J, K regardless of the circular interpolation plane.
Selca
Added M19 command to the G86 boring cycle to handle spindle indexing on the Selca post processor.
Siemens 840d, Siemens 840d Inspection
Output the initial WCS code at the beginning of the program prior to the workpiece declaration for proper controller simulation.
Tormach
Added probing support to the Tormach post processor.
Mill-Turn Post Processors
Hurco TMM8, Hurco TMM10, Hurco TMX8MY, Hurco TMX10MY, Hurco TMX8MYS, Hurco TMX10MYS
Added G28 Support and ability to position parts catcher to the Hurco mill turn post processors.
Mazak Quick Turn 100-M, Mazak Quick Turn 100-MS, Mazak Quick Turn 100-MY, Mazak Quick Turn 100-MSY, Mazak Quick Turn 200-M, Mazak Quick Turn 200-MS, Mazak Quick Turn 200-MY, Mazak Quick Turn 200-MSY, Mazak Quick Turn 250-M, Mazak Quick Turn 250-MS, Mazak Quick Turn 250-MY, Mazak Quick Turn 250-MSY, Mazak Quick Turn 350-M, Mazak Quick Turn 350-MY, Mazak Quick Turn 350-MSY, Mazak Quick Turn 400-M, Mazak Quick Turn 450-M, Mazak Quick Turn 450-MY
Fixed an issue where the XZ output could be rotated during a turning operation in the Mazak Mill/Turn post processors.
Mazak EZ 8M, Mazak EZ 8MY, Mazak EZ 8MSY, Mazak EZ 10M, Mazak EZ 10MY, Mazak EZ 10MSY, Mazak EZ 12M, Mazak EZ 12MY, Mazak EZ 12MSY, Mazak QTU 200-M, Mazak QTU 200-MS, Mazak QTU 200-MY, Mazak QTU 200-MSY, Mazak QTU 250-M, Mazak QTU 250-MS, Mazak QTU 250-MY, Mazak QTU 250-MSY, Mazak QTU 350-M, Mazak QTU 350-MS, Mazak QTU 350-MY, Mazak QTU 350-MSY
Turning Post Processors
Doosan Turning
Added support for drilling with feed per revolution in the Doosan turning post processor.
Fanuc Turning
Added support for drilling with feed per revolution in the Fanuc turning post processor.
3. New Machines
Machine Library
The Machine Library lets you manage your machine tools by using Machine Configurations to define your available machines and resources. These configurations can automate the settings in your Job Setup.
There are many Machine Configurations available in the standard library.
You will have available configuration files for some of the leading machine manufacturers:
B1
BX
B1 SE
B1 SE PLUS
Hurakan
         IdeaPrinter
F1
F100
F100L
F2
The easiest way to get started, is to copy an existing configuration that matches some of the characteristics of your machine.
HP Jet Fusion 3D 5000 Printer
5. New Workholdings
Workholding Library
The Workholding library lets you add a workholding equipment (vise, table, tombstone, etc.) to a manufacturing model. Those can be found in the "CAM Samples" project folder that you can find in the Fusion 360 data panel:
- 57 Zero-Point Accessories
The Autodesk App Store helps you to easily extend the power of Autodesk Fusion 360.
In the CAM category you will find many useful extras for your manufacturing applications.
Harvey Tool Resources
The Harvey Tool Resources add-in provides a user-friendly interface that allows you to download Harvey tools into your Autodesk® Fusion 360® tool library.
The add-in allows you to download a Harvey tool to your Fusion 360 tool library by simply entering the Harvey tool number and clicking add tool.  It also allows you to search the Harvey Tool online catalogue and add tools from the catalog to your tool library.
Our development team is always working to update and fix the Autodesk CAM Post Processor engine. These modifications are not related to a specific postprocessor (as described above) but affect the entire library or at least the post processors using that specific class. The current post processor kernel is 4.5991.
API.pngUpdated the machine code to properly handle the turret definition.
API.pngFixed retract and reconfigure movements against the stock.
You can find here all the information regarding the Autodesk CAM Post Processor engine.
Click here to see the previous What’s New release.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
0 REPLIES 0
