How do I change the number of dismal places used in the Inspection feature? I set up my Tolerances in the Manual Inspection but when I go to use the Record Manual Inspection feature it fails some of the tolerances because it's using five numbers past the decimal. I want to change it so it uses only Four. Here is an example of what I mean. I set the tolerance at 0.001 the Dimension is 3.9370. My measurement taken was 3.9370. it generated my Nominal to 3.93701 and it failed because of a deviation of -0.00001. If this was only using 4 numbers past the decimal place it should have passed. How do I make this change???
