Ive posted this on reddit already this morning. (https://www.reddit.com/r/Fusion360/comments/15cpcs6/problems_with_dims_of_mating_parts/). Im reposting here as I may get more insights into what I can do.
I am trying to make a jig to hold a guitar neck blank which also holds the outlined neck (to keep the same centerline when making them). The material of the jig is walnut (I had some lying about), and the test object is also the same walnut (See first image)
images are here: https://imgur.com/a/BkfQkei
I am having problems getting the test object to fit into the jig.
The problem is across the dimension that is shown the 54.694mm dim (2nd image). The Test object seems dimensionally accurate on measure for all dimensions.
The negative shape (pocket) in the jig is about 1mm too narrow, the test object is too wide to fit into the slot. I have provided the details of the tool path (last image),
Any advice on what can be done to correct this, I’m a bit lost, would the compensation type help me in any way… its set to computer at the moment. I could set it to in control and manually edit G41/G42 code but thats not something I want to be guessing about
stock to leave is not clicked on the passes
All models were extruded from the same set of sketches so they all 'fit' within fusion.
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Thanks for taking a look, I've attached the file publicly below, its not commercially sensitive as I am a hobby maker.
I'm curious to know what you think.
I have solved this.
It was a simple case of mixing up 2 end mills
one was 6mm and the other was 6.35 mm diameter
The Fusion 360 model was using the 6.35mm bit... the 6mm bit was on the machine... my mistake
Dont mix your bits up!
Thanks for all the help.
