Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Fagor 8055m 5-axis drilling
2 REPLIES 2
firebloodphoenixHRBBH
202 Views, 2 Replies
Hello, I'm trying to write a Fagor 8055m’s 5-axis post-processor, but I cannot seem to get the 5-axis drilling function to work properly. It is supposed to output Y as a zero, iow. position B,C then drill. I'm using the DMS Faggor 8055 with several modifications.
The Markino slim3n on the post-processor library seems to be the closest to be correct but using A&C instead. But I have no idea how the output set X to zero.
This is my first post-processor so any help would be appreciated, also if you see a glaring issue I this post let me know.
Tags (3)
Labels (3)
2 REPLIES 2
Have you tried either of the HSM Post Library posts that are available?
They are located here: https://cam.autodesk.com/hsmposts
Search for DMS and there is a post for the 8055 and 8065
Zak Welsh
Zakary Welsh Machine LLC
As I said, I am using the DMS. but I think I solved that issue. I set optimizeMachineAngles2(1). but now i have issues getting the head rotating to the position i want.
Technology Administrators
