firebloodphoenixHRBBH
278 Views, 2 Replies
Fagor 8055m 5-axis drilling
Hello, I'm trying to write a Fagor 8055m’s 5-axis post-processor, but I cannot seem to get the 5-axis drilling function to work properly. It is supposed to output Y as a zero, iow. position B,C then drill. I'm using the DMS Faggor 8055 with several modifications.
The Markino slim3n on the post-processor library seems to be the closest to be correct but using A&C instead. But I have no idea how the output set X to zero.
This is my first post-processor so any help would be appreciated, also if you see a glaring issue I this post let me know.
Tags (3)
Labels (3)
Have you tried either of the HSM Post Library posts that are available?
They are located here: https://cam.autodesk.com/hsmposts
Search for DMS and there is a post for the 8055 and 8065
Zak Welsh
Zakary Welsh Machine LLC
As I said, I am using the DMS. but I think I solved that issue. I set optimizeMachineAngles2(1). but now i have issues getting the head rotating to the position i want.
