I love the newest post so far for fadal, but I have ran into a snag where it is posting the tap cycles in fadal format one and I no longer have a dialogue box to change that in the post processor settings. I have moved to an older post processor for the time being while tapping.
Solved by serge.quiblier. Go to Solution.
can you explain with greater detail what is wrong in the output?
Can you share for example the old generated nc code, and the new one?
If changes needs to be implemented in the post, there is not enought information.
Regards.
Regards.
I found that it was user error and i had the fadal format chose and not the fanuc which would be format two in the machine control.
yes that is it!
