Fusion Manufacture
stepdowns are clustered in "Layers"
4 REPLIES 4
dansemur
169 Views, 4 Replies
i dont understand why it does this, it takes 4x the time it usually does to cut.
using a cnc to carve 3d parts
looks like each cluster of passes are .15 though
edit:
i guess the toolpath I usually get are evenly spaced in the z axis to whatever step down I command. Now it’s more like a bunch of .02 pass bunched up in .1 with a .05 pass at the end. Here’s the link to the copied file
https://a360.co/44xNgFb
4 REPLIES 4
a.laasW8M6T
in reply to: dansemur
That looks like expected behavior, the tool steps down at the maximum roughing stepdown, then machines everywhere it can, before moving down to the next 0.15 stepdown
Can you describe what you are expecting it to do? maybe I'm misunderstanding.
If you could share your file here it will make it easier to troubleshoot
dansemur
in reply to: a.laasW8M6T
matty.fuller
Turn off Flat Area Detection, as there are obviously no flat areas in this model. It will calculate a LOT faster and cleaner.
You're also looking at 2 toolpaths laid over the top of each other, turn off the visibility of the Contour operation and you'll see that the Pocket operation has nice even stepdowns.
dansemur
OMG yes! i knew the toolpath were visibles, but indeed the falt area detection has made it alot quicker AND solved my problem, the passes are now clean. the problem happened in both the pocket and contour. thx so much!
