is it possible to extend and links in extend move? this is paralell strategy, i can increase the entry and exit, but but not the links between, or i need to extend the surface?
Solved by a.laasW8M6T. Go to Solution.
At present, you need to extend the surface
-EDIT-
It does appear that using a Machining Boundary and Boundary Offset does seem to get us what we're looking for. Past history tells me that should have been a "waterfall" result, so I'm not sure when that was changed or perhaps I'm just conflating it with something else 🤔
-EDIT-
Hi
Seth the reason its not waterfalling here is that you have a bottom height containing the toolpath.
If you change that to model bottom then it does waterfall
Containing with the bottom height works fine for a flat surface but will be problematic for other sloped/curved geometry.
Flow is the only toolpath that properly applies tangential extensions to surfaces, other strategies will require making extended surfaces in the design workspace
Hi
@a.laasW8M6T wrote:
Hi
Yeah, that was something that occurred to me late last night as I was dozing off. I'm still curious as to why it actually extended the surfaces though. Truthfully, I've never used a Parallel toolpath on a purely flat surface (we have better toolpaths for that task), so it's likely that it's always been able to extend like that.
@a.laasW8M6T wrote:
Hi
What strategy is allowed to extend without extending surfaces? Today I had to use one strategy countour, apply extended and it works. Maybe only parallel don't allow
