Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Extend links
4 REPLIES 4
nubrandao
225 Views, 4 Replies
Extend links
is it possible to extend and links in extend move? this is paralell strategy, i can increase the entry and exit, but but not the links between, or  i need to extend the surface?
4 REPLIES 4
seth.madore
in reply to: nubrandao
At present, you need to extend the surface
-EDIT-
It does appear that using a Machining Boundary and Boundary Offset does seem to get us what we're looking for. Past history tells me that should have been a  "waterfall" result, so I'm not sure when that was changed or perhaps I'm just conflating it with something else 🤔
Seth Madore
a.laasW8M6T
Hi
Seth the reason its not waterfalling here is that you have a bottom height containing the toolpath.
If you change that to model bottom then it does waterfall
Containing with the bottom height works fine for a flat surface but will be problematic for other sloped/curved geometry.
Flow is the only toolpath that properly applies tangential extensions to surfaces, other strategies will require making extended surfaces in the design workspace
seth.madore
in reply to: a.laasW8M6T
@a.laasW8M6T wrote:
Hi
Yeah, that was something that occurred to me late last night as I was dozing off. I'm still curious as to why it actually extended the surfaces though. Truthfully, I've never used a Parallel toolpath on a purely flat surface (we have better toolpaths for that task), so it's likely that it's always been able to extend like that.
Seth Madore
nubrandao
in reply to: seth.madore
What strategy is allowed to extend without extending surfaces? Today I had to use one strategy countour, apply extended and it works. Maybe only parallel don't allow
