Edit a machine for the setup sheet. For configuration the Emco Concept mill 55
Hello, can someone explain to me how to configure Emco Concept mill 55 data step by step. Is it confusing for me?
Data Emco Concept mill 55:
Travel in X longitudinal 190 mm (7.48")
Travel in Y latitudinal 140 mm (5.51")
Travel in Z vertical 260 mm (10.24")
Effective Z-stroke 120 / *190 mm (4.7 / 7.5")
Distance spindle nose - table 77 – 337 mm (3.03 x 13.26")
Table
Clamping area (L x W) 420 x 125 mm (16.54 x 4.92")
Max. table load 10 kg
2 T-slots DIN 650 11 mm (0.43")
T-slot spacing 90 mm (3.54")
Milling spindle
Bearing type roller bearing
Tool change (Option)
No. of tool stations 8
Max. tool weight 1 kg
Max. tool diameter 40 / *60 mm (1.6 / 2.4")
Motion speed tool swivel arm 10 m/min (0.39 ipm)
Tool clamping automatic
Milling spindle drive
Motor power 3 phase asynchronous motor 0,75 kW
Speed range 150 – 3500 rpm
Max. torque 3.7 Nm (2.72 ft/lbs)
Speed with optional engraving spindle 14000 min-1
Feed drive
3 phase step motor in X / Y / Z axis 0,5 µm / 0,5 µm / 0,5 µm
with resolution
Rapid motion speed and feed rate X / Y / Z 0 – 2 m / min (0 – 78.74 ipm)
Average positioning variation in 8 µm / 8 µm / 8 µm
VDI/DGQ 3441 in X / Y / Z
Feed power X / Y / Z [N]“ 800 / 800 / 1000
2) I have the solids of the clamp jaw and the table. How can I use it in setup? Can I add it to the configuration of my machine?
3) How to configure the holders? To use the SK-30 cones in my tool store.
