- Mute
- Permalink
- Report
-> Description
*Description: Generic 3-axis
*Model: Emco Concept 55
*Vendor: EMCO
*CNC control: Sinumerik 840d
-> Description
*Depth: 0 mm
*Height: 0 mm
*Weight: 0 kg
*Width: 0 mm
-> Capacities
*milling= "yes"
*turning= "no"
*cutting= "no"
*Automatic tool Changer= "yes"
*Support tool preloader= "yes"
*Number of tool: 8
*Maximum feederete
*Maximum block processing speed
-> Workpiece X
*Maximum workpiece X:
*Maximum workpiece Y:
*Maximum workpiece Z:
*Weight capacity: 0 kg
-> Kinematics
->-> X Linear axis
*Coordinate= "X"
*Custom name=
*Home Position: 0 mm
*Resolution: 0
*Maximum Feedrate: 2mm/min
*Offset X: 0mm
*Offset Y: 0mm
*Offset Z: 0mm
*Range Min: 0 mm
*Range Max: 0 mm
->-> Y Linear axis
*Coordinate= "Y"
*Custom name=
*Resolution: 0
*Offset X: 0mm
*Offset Y: 0mm
*Offset Z: 0mm
*Range Min: 0 mm
*Range Max: 0 mm
->-> Z Linear axis
*Coordinate= "Z"
*Custom name=
*Resolution: 0
*Offset X: 0mm
*Offset Y: 0mm
*Offset Z: 0mm
*Range Min: 0 mm
*Range Max: 0 mm
->-> Table
*Manie Table on which to plane the parts
->-> Spindle
*Spindle type= Primary
*Orientation X: 0
*Orientation Y: 0
*Orientation Z: 1
*Spindle speed Min: 150
*Spindle speed Max: 3500
-> Machining time
Freedrate ratio (%): 100
Tool change time:
-> Coolant
-> Post Processing
Disabled= "no"
Flood= "no"
Mist= "no"
Through Tool= "no"
Air= "yes"
Air Through Tool= "no"
Suction= "no"
Flood and Mist= "no"
Flood and Through= "no"
-> Setup Sheet
-> Multi-Axis
Fusion
