engineguy
@ferminduaso
Hi, hope this helps you a little, a couple of images and a Screencast.
Here is an example of the Machine Configuration with your values entered.
I will attach the .machine file for you in a Zip file.
Creating your tool holders requires some work, you need to go to your "Tool Library" and select + on the toolholder icon to add a toolholder, these you will build up using discs and cones, you don`t need to do the 30 taper part of the tool holder as that will in real life be actually inside the spindle although there is no reason why not if you want to do it that way, you will need to have one of each type of holder that you possess, example an ER32mm Collet holder, or a 10mm sidelock (Weldon) type, you will need to actually measure each of them and create your holder as shown in the image below, from your image it looks like you already know where to go!
Next, your fixture, I see that you have already modeled your table and vise so that is a good start, when you create the model you want to machine it will need to match the coordinates of your Vise, look at the image below for how my sample setup looks.
When you do your setup you will select the "Relative Size Box" and no additional stock if that is actually the size of the material you are machining. you will have to use the "Move/Copy" facility to move your Vise jaws and your Model so that it fits properly in the jaws. See Screencast below :slightly_smiling_face::slightly_smiling_face:
Hope that is of some help to you, files attached below for you.
Regards
Rob
