Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Disable G97 for a livetool
8 REPLIES 8
Message 1 of 9
JJackrabbit
331 Views, 8 Replies
Post: https://cam.autodesk.com/hsmposts?p=siemens_mill-turn
Follow up on my other topic.
https://forums.autodesk.com/t5/fusion-manufacture/live-tooling-toolpath-feed-not-correct/m-p/1278767...
Did some more testing and it seems if my program calls a G97 twice. The machine is trying to follow the speed of the live tool. Moving at high speeds = broken cutter.
What I want to do is disable the G97 calls for the live tools "G97 S1=4000 M1=3"
This is my live tool. But it should drop the G97.
It runs perfect without the G97 and I don't see why I would want G97 for a live tool?
8 REPLIES 8
Message 2 of 9
RoccoHilton
in reply to: JJackrabbit
Why don't you attach the post you want to edit? You didn't do that in the last entry either
Message 3 of 9
JJackrabbit
in reply to: RoccoHilton
Message 4 of 9
RoccoHilton
Is this what you wanted to get?
Message 5 of 9
JJackrabbit
That's the post I'm using/modifying.
Message 6 of 9
RoccoHilton
No. In this post, I added a feed per revolution in turning operations
Message 7 of 9
JJackrabbit
Ah! I will check it
Message 8 of 9
JJackrabbit
Did some testing but it doesn' work.
I have 2 exact 2D contour operations with a live tool (axial).
The first operation is working correctly. It is using feedrate mm/min, which I programmed in the 2d contour operation.
But
On the exact same second operation it switches to feed per rev. I can see it on the control.
So somehow it is being switched?
When I remove the G97 of the second operation, it works fine
Message 9 of 9
RoccoHilton
could you attach an example of such a program?
