Post: https://cam.autodesk.com/hsmposts?p=siemens_mill-turn
Follow up on my other topic.
Did some more testing and it seems if my program calls a G97 twice. The machine is trying to follow the speed of the live tool. Moving at high speeds = broken cutter.
What I want to do is disable the G97 calls for the live tools "G97 S1=4000 M1=3"
This is my live tool. But it should drop the G97.
It runs perfect without the G97 and I don't see why I would want G97 for a live tool?
Why don't you attach the post you want to edit? You didn't do that in the last entry either
Did some testing but it doesn' work.
I have 2 exact 2D contour operations with a live tool (axial).
The first operation is working correctly. It is using feedrate mm/min, which I programmed in the 2d contour operation.
But
On the exact same second operation it switches to feed per rev. I can see it on the control.
So somehow it is being switched?
When I remove the G97 of the second operation, it works fine
