Am trying to cut holes (Six to be exact) of more than one size and form in a small wooden part. I am not particularly interested in the sequence in which the holes are cut. But I would like to have them all cut before the part itself is cut. So far, at least one hole has been left to cut and my machine returns to do that hole before calling it quits. Of course, that last hole has a strange form as the maller form in the hole moved back and forth while the machine was cutting it.
What am I doing wrong?.
Thanks for any and all replies,
Solved by engineguy. Go to Solution.
Solved by Warmingup1953. Go to Solution.
Solved by jcamve. Go to Solution.
My reply to you. Thanks for the reply and the explanation on how to export a file.
