Fusion Manufacture
Cutting 10 inch into stock.
3 REPLIES 3
23doescherti
231 Views, 3 Replies
I have been using fusion 360 for a few month to run my cnc router it has been great other than one bug. On the start it try to cut 10 inch into the stock. I have to remove the commands manly in the gcode. This is not a one time problem it happens every time i use it. My gcode is attached the problem is at line 22, 3118 and 3121. Any ideas on how to fix this?
3 REPLIES 3
tallisb
in reply to: 23doescherti
Hello-
Are you able to share your f3d file?  That way we can take a look at the Manufacturing Setup, depths, etc.
Thank you-
Brad
Brad Tallis
Fusion 360 Technical Specialist
23doescherti
in reply to: tallisb
Here you go
scottmoyse
This is a post processor issue and not a Fusion bug. The correct place to get an answer is over here: https://forums.autodesk.com/t5/fusion-360-manufacture/bd-p/2070
Where did you get your post processor?
Scott Moyse
Product & Platform Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Technology Administrators
