Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Cutting 10 inch into stock.
3 REPLIES 3
23doescherti
245 Views, 3 Replies
I have been using fusion 360 for a few month to run my cnc router it has been great other than one bug. On the start it try to cut 10 inch into the stock. I have to remove the commands manly in the gcode. This is not a one time problem it happens every time i use it. My gcode is attached the problem is at line 22, 3118 and 3121. Any ideas on how to fix this?
3 REPLIES 3
tallisb
in reply to: 23doescherti
Hello-
Are you able to share your f3d file?  That way we can take a look at the Manufacturing Setup, depths, etc.
Thank you-
Brad
Brad Tallis
Fusion 360 Technical Specialist
23doescherti
in reply to: tallisb
Here you go
scottmoyse
This is a post processor issue and not a Fusion bug. The correct place to get an answer is over here: https://forums.autodesk.com/t5/fusion-360-manufacture/bd-p/2070
Where did you get your post processor?
Scott Moyse
Product & Platform Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
