- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I watched the Autodesk tutorial about custom setup sheets, followed the instructions and I am not able to output the new custom setup sheet.
I set the setting in preferences to enable Setup Sheet Configurations and then went to the Manage tab and edited the settings and saved it as a new configuration.
Now, when I right click on my setup and select Setup Sheet, I do not get the same new and improved experience as the person in the autodesk demo video.
You are supposed to get a Publish Setup Sheet window where you select a cloud location and name to upload the setup sheet.
I still get the same file browser window to select a folder on my PC.
I also do not get the new window where you select which configuration of setup sheet you want to generate.
Fusion just generates the same uncustomized setup sheet and saves in on my PC.
What am I doing wrong?
Dave
