In the past if you ran a simulation to the end then clicked the play button again it would start the simulation again with the original stock. Now if I do that the stock remains as the finished part, is that an intended change\improvement? Same problem if you click the go to previous operation.
Mark Hughes
Owner, Hughes Tooling
Solved by ktorokU233T. Go to Solution.
@ktorokU233T Must have click that by mistake! Didn't know that was an option. Edit. Just noticed it's the same on 2 PCs on different accounts so I guess set by an update.
Mark Hughes
That's been in the software for a fair bit of time (I think January release). Not sure that we did anything to change the default settings 🤔
I had noticed it for quite a while but not that big a problem so I didn't ask before. I was working on some turning setups yesterday and you generally need a slower simulation compared to milling or it's finished before you can blink! So that's when I thought I'd ask. There was an update a couple of months ago that reset all my defaults on both PCs at work and my laptop so maybe that's when it changed.
Mark Hughes
