I downloaded a bearing file and want to create a single component to add to an assembly drawing.
I can use the Combine command and select target and tool bodies but I still end up with 2 files. The inner race, my target body, is not included in the combined body.
What am I missing?
Thank you for your help.
Solved by tgford58. Go to Solution.
