Fusion Manufacture
Post processor issue Heidenhain
1 REPLY 1
llBPM35
112 Views, 1 Reply
Hi.
I have a little issue with a PP i am trying to make.
I have addet some features to the "User defined properties" One of them is a Break control of the tool. My problem is that it does the check before the first tool. I need a code that skips the check before the first tool.
The code look like this now.
Is there a place where you can see all the codes and what  they mean
1 REPLY 1
a.laasW8M6T
in reply to: llBPM35
The is the Fusion post training guide:
https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf
You probably need to add an if statement that checks if its is the first section.
if(!isFirstSection()){Run tool break code}
the above would would run the code if is is NOT the first section
