Fusion Manufacture
Document tool library gone
4 REPLIES 4
boggsjon141
381 Views, 4 Replies
Good evening,
So I have a Fusion file that is now missing the tool document. I cannot get fusion to repopulate it. This is on a design that has been opened and closed a lot, with a lot of revisions, and a lot of tool data, tool switching, setups, toolpaths, ect. It's the only document where it is missing.
Leading up to it I copy and pasted a tool from another file into this one. Right clicking edit tool on the pasted tool said the tool library had crashed. Restarted fusion. The tool I pasted into this toolpath from another file was a 1/4 4fl. After the restart the tool and tool number was changed to T11 from the pasted tool number T22. T11 is used in the same setup, but is a thread mill. So that was strange.
Using the repair utility didn't result in any fixes. And re installing didn't result in any fixes. All my CAMposts, cloud library's, CAMmachines, and templates were deleted though. Luckily they seem to be backed up in 'assets'. I found it strange they didn't auto show up where you would expect them after the reinstall, because typically they do.
Tried also turning off any preview features. Around the same time I was messing around with the preview HIGH DPI settings, but I'm not sure if that's related.
Thanks for any help 🙂
Labels (2)
4 REPLIES 4
jeff.pek
in reply to: boggsjon141
The best way for us to help with this is if you can share the document (export and attach here, or send as PM).
  Jeff
boggsjon141
PM sent, thank you!
Farzati.Scott
Same thing just happened to me.  A lot of work on a model and tooling.  Now it's tool library is not showing up?
boggsjon141
in reply to: Farzati.Scott
I messaged jeff.pek and he got my document squared away. You might want to pm him your issue along with your fusion file so he or someone else can take a look at it.
