Are there any updates on the way for Stock definition at all ?
The ability to define stock via a solid body in line with HSMXpress etc would be handy, so stock modes could be
None : - outer profile of the part to be machined
Fixed or relative box : - as is
From Sketch : - projected from a sketch chosen from browser
From Solid body : - choose a solid body from the browser
For me personally choosing a solid body would be the handiest addition
Solved by jeff.walters. Go to Solution.
That's good to hear Jeff, as for the 'Continue' option, this exists currently in HSMXpress Stock definition.
I'm no expert, but I assume that if for instance you specify the stock in Setup 1, then in Setup 2, you can specify the same stock but check the 'Continue' option so that the actual stock removed by operations in Setup 1 is ignored by operations in Setup 2 ?
Hope that makes sense.
Cheers.
that is already in HSMWorks so yes it will be brought across to Fusion and Inventor. Again the timing is the unknown right now.
