How can I restrict a helix bore so that I do not get a slug in the middle of the hole? Basically I have two holes in my part that I want to helix into and then finish the diameter, but I'm wondering if a pocket routine may be the better option with a finish pass and a helix entry. In which case, is there an easy way to center the helical entry on a circular pocket?
Solved by jeff.walters. Go to Solution.
This can be done quite easy by going to the Passes tab and selecting Multiple Passes
