Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
CAM Stock Definitions
5 REPLIES 5
Trigg3r
807 Views, 5 Replies
Are there any updates on the way for Stock definition at all ?
The ability to define stock via a solid body in line with HSMXpress etc would be handy, so stock modes could be
None : - outer profile of the part to be machined
Fixed or relative box : - as is
From Sketch : - projected from a sketch chosen from browser
From Solid body : - choose a solid body from the browser
For me personally choosing a solid body would be the handiest addition Man Very Happy
Tags (2)
5 REPLIES 5
Trigg3r
in reply to: Trigg3r
Also, will there be the option of 'Continue machining from previous operation ?'
Cheers.
jeff.walters
Its being worked on but we don't know for sure when it will be released. can you expand on the "Continue machining from previous operation". what would you like to see happen.
Jeff Walters
Senior Support Engineer, CAM
Trigg3r
in reply to: jeff.walters
That's good to hear Jeff, as for the 'Continue' option, this exists currently in HSMXpress Stock definition.
I'm no expert, but I assume that if for instance you specify the stock in Setup 1, then in Setup 2, you can specify the same stock but check the 'Continue' option so that the actual stock removed by operations in Setup 1 is ignored by operations in Setup 2 ?
Hope that makes sense.
Cheers.
jeff.walters
that is already in HSMWorks so yes it will be brought across to Fusion and Inventor. Again the timing is the unknown right now.
Jeff Walters
Trigg3r
Thanks Jeff, looks like it's a waiting game then 🙂
