Fusion Manufacture
CAM on German machine
5 REPLIES 5
doris_fischer
987 Views, 5 Replies
I'm working on a laptop with language setting=German (Windows 7, OS = English).
I was running through the new tutorials, which are really great. With the CAM tutorial first I realized that the UI appears mixed with German and English (see attached CAM Setup.jpg and CAM Setup2.jpg). But it's working.
The issue is now on the "Select Tool" command (see attached CAM Select tool.jpg). For any reason the selection window is empty.
Please advice how to proceed here.
Doris
Doris Fischer
Education Account Manager
5 REPLIES 5
rishivadher
in reply to: doris_fischer
Hi Doris
To change the language to first as seen on the picture one (eng.png)
And the second is just rigth CLICK on the option you prefer to select it(Untitled.png)
The third question don’t understand what is the issue, but use the sample library for this test as the pic shown (lib.png)
Best your truly Rishi
rishivadher
in reply to: rishivadher
our to change the language, flow the path
doris_fischer
Thanks for the answer, Rishi.
I know how to change the language settings on my machine, but this is not what I want to do.
The point is, that with German (non English settings) not everything runs as described in the tutorial.
As next on step 16/66 there is no tool #11 with diameter of 25mm (see screenshot attached).
Doris
Doris Fischer
hansun_zhu
Hi Doris,
Could you please go to "Sample Libraries->Sample Tools->", scroll down the window and then click on an 25mm tool, then click Edit on the bottom of the dialog, in the Edit dialog, active the "General" tab, input 11 in Number, then click Ok to finish the edit operation, then you can click Select button on the library dialog to select this tool.
See attached image for reference.
Hansun
doris_fischer
in reply to: hansun_zhu
Hi Hansun,
Thanks for the advice. It works.
Doris
Doris Fischer
Technology Administrators
