Fusion Manufacture
Cam 360 Setting the Origin
1 REPLY 1
phinsil6
501 Views, 1 Reply
After using Cam 360 to machine a few parts, pretty successfully, I have noticed that there doesn't really seem to be an option for setting the height from the origin (in my case, Top of stock, Bottom left corner) and the first operation.  Basically, no matter what the clearance height or retract height, the Z stays at height 0 until it gets to the X,Y of the first operation, and then it goes to the clearance height.
How do I get it to go to e.g 10 mm off the top of the stock (x=0,y=0,z=0) to the first operation X,Y and then do it's plunging and such?
1 REPLY 1
bobvdd
in reply to: phinsil6
Did you verify the position of your Top and Bottom height plane? Can you post your file here so we can have a look?
Bob Van der Donck
Principal UX designer DMG group
Technology Administrators
