ballnose going deeper than it should
jim_carter2LMUU
jim_carter2LMUU
New to Fusion but I am finding it extremely user friendly!
I do have a small problem though!
When I am machining a surface I am finding that the CAM program is going 1mm deeper than my model?
Am I missing something?
Machine being used is an XYZ RLX and the postprocessor runs a basic Fanuc code.
I have added a pic to show the pocket I am trying to machine. On the step file it is 15mm deep but in reality it ends up 16mm deep!!??Pocket.jpg
seth.madore
It's possible that it's a stock and WCS definition error. Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
You're using the generic Fanuc post, correct?
Seth Madore
jim_carter2LMUU
Yes I am using the generic fanuc post
see attached
seth.madore
Problem found:
You have 1mm stock on, and your WCS is set to the top of the stock, not top of model. Your code is going to be 16mm deep
Seth Madore
jim_carter2LMUU
Thank you for your help!!
