Fusion Manufacture
Multi Axis Contour
5 REPLIES 5
msm19b034
200 Views, 5 Replies
Multi Axis Contour
I have frustum based component with some pockets on the curved surfaces. I want to manufacture the part using multi axis contouring. Initially i have used multi axis swarf to cut a frustum from cylindrical stock, now i want to cut the pockets on the curved surface using multi axis contour which i am unable to perform.
I am encountering some errors like -
no passes to link
empty toolpath
I have attached some screenshots for reference and the .f3d file.
please help
Thank you
5 REPLIES 5
seth.madore
in reply to: msm19b034
I'd think you'd want to use a Swarf toolpath, no?
Seth Madore
msm19b034
in reply to: seth.madore
I want to make a pocket is it possible with a swarf path?
msm19b034
please refer to the image. if I use swarf i am getting something like that in the image but that is not my desired output.
please help
msm19b034
i see that you have solved the multiaxis contour problem, can you please share the file
seth.madore
Here you go 🙂
Still poking away at the floor finishing
Seth Madore
