Solved by seth.madore. Go to Solution.
Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
I wish screen cast was still around
Titan 10 M op2 trace issue
Same...
Give this a view:
I can see videos on my home computer no problem. We must have a school IT issue
thanks for the tips. I saw the black/blue lines and I couldn't figure out what that was. In normal contour I could do open chain and deselect or add as need with the + - under the open contour. But I can work with that.
Is that covered in the video
New geometry selections
