Wondering why the 3D contour doesn't hit this face now? My tool is the same size, haven't moved the model positions either. This problem is happening now that I'm trying to machine the two interior faces on the "main holder". Thanks for any input.
Solved by Steinwerks. Go to Solution.
If you have selected a limit contour for the operation, click on the small red arrow - this will select the other side of the contour. I believe you've got the wrong side of this contour selected by default, so the milling ends before the correct edge. Hope that helps. Cheers
The face I'd like to have surfaced is on the box in the middle. It is the face that is in view, without any cut lines going across it.
Thanks for pointing that out about the Surface Clearance.
Try these settings. You might want to turn off Machine shallow areas and select Order By Islands as well.
Mark
Mark Hughes
Owner, Hughes Tooling
