Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
2D Contour cutting across corner
7 REPLIES 7
Message 1 of 8
taiello3154
380 Views, 7 Replies
I am trying to make the cutouts depicted in the picture using a 2D contour operation.  For some reason, the toolpath cuts a corner every 4 cutouts (circled in red).  This happens at the bottom of the toolpath and cuts through the center piece that I'm cutting out.  My machine isn't super rigid and that kind of a cut doesn't end well.  How can I get the operation to cut each hole the same way without cutting across?
Thanks for your help.
7 REPLIES 7
Message 2 of 8
brad_francola
in reply to: taiello3154
Hi.  Can you share your file?
There are several potential solutions but it would be easier to help if we can see you file.
Message 3 of 8
taiello3154
Hopefully this is what you mean - link below.  If not please let me know specifically what to share.
https://a360.co/442ppOa
thanks
Message 4 of 8
brad_francola
I'd like to figure out why you are getting that odd move.  But, for now, you can use a duplication pattern.  Program the first pocket and then duplicate that toolpath based on the relative geometry of each subsequent pocket.
Message 5 of 8
taiello3154
Thank you!
If you find out something about my original approach I would love to know....but for now this should work!
Message 6 of 8
seth.madore
It's nothing in your approach, it's just how the kernel has decided to solve for this contour. There's room for improvement, for sure.
In addition to what @brad_francola has suggested, another method is to just define a "Preferred Entry Point" on the far right wall. This will align all the start points with that selection:
Seth Madore
Message 7 of 8
brad_francola
@seth.madore I like your way better than mine in this scenario.
Message 8 of 8
taiello3154
Thanks to both for your quick replies.  Seems that either should work but I learned a lot from your suggestions....
