Want to make slots : trace is not working, slot neither
eric.thepaut3
Message 1 of 25
eric.thepaut3
first : how can i find my messages on this forum? I had dashboard in the past, but i can't find it know. Where it is?
So i tried to use trace to make slots from a sketch, but it makes only traces, normal maybe, no slots. I changed the bottom height but it does not go deep in the wood. I tried slot, but it wants pockets, and i don't have pockets, only a sketch.  So help would be fine...
https://a360.co/38wukgv
Replies (24)
Message 2 of 25
engineguy
@eric.thepaut3
If you are using the 2D Trace to follow a sketch line then under the Passes tab there is an option to do multiple depths using the "Axial Offset" facility.
Stay Safe
Regards
Rob
Message 3 of 25
fr33l0ad3r
In attached file  you can see projected toolpath. You can find it under "3D" tab.
Message 4 of 25
eric.thepaut3
OK, thanks. Let's keep 2D trace for now. So for a depth of 4mm with passes of 0.25, i must have 16 setpdown? I thought it was managing the number of setpdown itself... And what about the bottom height in height tab?
Message 5 of 25
fr33l0ad3r
Frets are curved so you need curved cut. Trace strategy will follow straight lines from sketch you using so you need to create extra geometry, or simply use projected strat
Message 6 of 25
daniel_lyall
What you need to do is a project to surfaces the fret sketches so the sketch is on the surfaces off the guitar part, then use the Project toolpath in the 3D list to cut them this is the 3D traces toolpath (it should be called 3D traces) it does it quite well, have a look in the attached file and look at the height settings I used as well.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 7 of 25
eric.thepaut3
OK many thanks Teal. I discover each tool. It's seems more adapted in fact to the fret slots. I will see that.
Message 8 of 25
eric.thepaut3
Yes sure, at first that's what i tried but i got an error. I don't remember which one.  I'll have a look. Thanks for the help.
Message 9 of 25
eric.thepaut3
16 x 25µm passes? It looks overkill! You must feed fast... You don't mention axial offset?
AFter doing the maths, i found that a pass should be 0.25 mm feeding at 400 mm/mn.
For my first try, i asked 0.5mm passes at 1000 mm/mn, the O.6 bit broke at once. Funny, but i had only one of these bits.
Thanks, i'll post the result tomorrow...
Edit : on the simulation it does not do 16 passes. Is it normal?
Message 10 of 25
engineguy
@eric.thepaut3
Suggestion, this something I have done in the past, buy a right angle adapter similar to the one in the image and use a Slitting Saw for your slots, it will do a slot in a single pass easily in wood, well worth the cost and the bit of work to adapt, the one I bought years ago isn`t around any more but there are lots of them that can be easliy adapted for the job. I used to do similar small width cuts in Aluminium, work great 🙂
Doesn`t have to be this particular one but it get the idea across 🙂 🙂 🙂
Stay Safe
Regards
Rob
Message 11 of 25
daniel_lyall
@eric.thepaut3 This is where modeling each feature in is important, you can get away with it if you know-how so if you want to leave the model as is do an offset surface in the surfaces workspaces off - what you want the bottom depth to be then project the sketch onto this surfaces then use the project toolpath (project toolpath + project) to cut it, in a new setup with the surfaces as the model.
This may sound slow but after a dozen or so times this becomes quite fast to do if you remember how to do it properly my bad.
In fusion you can use a lot of things in cam from surfaces, sketches, .stl models of the part after the first side has been cut and defeatured models, example attached done properly.
It shows a lot of crashes this is because the frets are not modeled in.
Daniel Lyall
The Big Boss
Mach3 User
Message 12 of 25
eric.thepaut3
Hello Daniel,
i'm back for my slots. I tried to project to surfaces, but i have the same problem than before, "cannot project into the same sketch". So i'm in the frets template sketch, i choose my surface, the fretboard, i have to pick a sketch geometry, and when i click on the first line (fret), i've this error message.  I've seen videos where they do it, but me, i can't. That's why i wanted to use traces. But i prefer the project tool. So how do you proceed? It's a long time i'm trying...
Message 13 of 25
daniel_lyall
Just Make sure all the settings in the toolpath you are happy with, in the attached file I have set it to cut 1mm axial depth of cut and it does a big silly lead and linking moves.
Modeling the toolpath in is the correct way to do it this is just a cheat.
Daniel Lyall
The Big Boss
Mach3 User
Message 14 of 25
eric.thepaut3
Many thanks Daniel, i appreciate the video. It's high level for me!!!
But in your file f3d, i disagree. With your settings, you ask for passes of 1mm each, with 3 steps down so you cut 4 mm deep in total. This bit needs passes of 0.25 each, so to have 1.75 mm deep for the fret, it's max stepdown : 0.25, number of steps down : 7 .  I think at least. The simulation is fine.
Last time i tried, i broke 4 bits. I had 5 of them. So only one left.  LOL
Tell me if you confirm what i say...
Message 15 of 25
daniel_lyall
Redo the offset surfaces to the depth you want then you can use what is here to put a formula into the text box for the number of step-downs.
I could not be bothered reading back through your post to find the depth you wanted, lazy yes that's why I called it out so you knew to look.
Daniel Lyall
The Big Boss
Mach3 User
Message 16 of 25
eric.thepaut3
Thank you Daniel for your help, i could do my fretboard slots without breaking my 0.6 mill.
But about the 3D finish, you seem to use parallel operation pour the radius, i used it also with success. But for my back of neck, i used scallop, and the tool did not go to true depth and now i've got a reverse filet on the neck. I not the first time i'm disappointed by scallop, do you make the back of the neck with parallel?
Can i do all the finish with parallel?
About simulation, is it possible to see the part after simulation.
I'll post pics...
my file https://a360.co/2V1bt5p
my scallop is "scallop galbe" in "manche dos" set up
Message 17 of 25
eric.thepaut3
The picture of the non finished scallop :
Message 18 of 25
daniel_lyall
The bits the arrows are pointing to select them and delete them, the bits in the circles are part of the problem it is a dirty surface, just deleting the 2 bit the arrow is pointing makes a difference.
It is more of a selection issue the tool is going to where it is meant to go, it needs to go past there what is not an easy thing to do.
In the attached file I have given you 3 options I have the center of the tool going to the center of the toolpath edge with the tool outside boundary and the -.01 offset and using the avoid/touch surfaces command to stop the cutting go to places it does not need to go to as the contour toolpath will do it.
Just have a look at where I set the toolpath it takes a bit of mucking around to get it correct but this is something all users have to put up with some of the time.
Daniel Lyall
The Big Boss
Mach3 User
Message 19 of 25
eric.thepaut3
how do you delete a line like this? I can select it, but after? I tried right click and delete, but it don't delete.
Message 20 of 25
daniel_lyall
Just what I show in the video delete.
Daniel Lyall
The Big Boss
Mach3 User
