Hi @ELAFING,
Yes if you duplicate the semi finish toolpath, move this to after the probing operation. Remove the stock to leave this should then do what you are after.
I see this being implemented in 2 scenarios.
1: A one off part.
In this case I would semi finish the feature, add a stock to leave on the feature but make sure the finishing stepover on the feature is the same as the stock to leave.
I am doing this to give representative forces on this semi finishing cut that will then be on the finishing cut. We know that tool wear is as much about deflection as wear itself.
I then do the probe geometry toolpath and select this previous milling operation as the reference operation.
Now I do the final milling operation.
Optionally I could probe the feature again to ensure it is prefect, tick the out of size action in Fusion and set the correct tolerances. (You can also tick print results to get this output)
2: Repeat production.
Similar to the one off part, but here I am improving the quality of the next part while still checking the part I have just machines is correct to tolerance.
I machine the feature fully.
Then add a probe geometry feature with tool wear update and out of size action.
This will check that the part I have just made is correct to drawing, but with the added benefit of improving the quality of the next part by updating the tool wear.
Richard Stubley
Product Manager - Fusion Mechanical Design
