Tool movements are backwards
Hi all,
Trying to resolve an issue with tool orientation after posting. I posted another question about this here, got to a point but that thread now has gone dead but I still do not have it resolved.
Here is that post.
My machine is a Sherline chucker lathe which is a gang tool lathe. My control is a Centroid Acorn running CNC12 software and Centroid turning post.
The issue is when running the job on the machine the tool movements are backward for my cut-off tool. It rapids directly into the endpoint of the cut then pulls back. I need it to rapid just above the part/stock, plunge straight down in +X, make the cut and retract straight out in -X. It's not doing what you would expect. Its starting the cut in +X.
I have my tool set to bottom side orientation and defined as a turret tool with 104 in tool set up as per Fusion tech support.
The issue is the centroid post is not doing whatever conversion it needs to for the orientation. SO how to get this all working?
The guys on the Centroid forum are saying program with negative numbers but im not exactly sure what values to change in Fusion? IS this the only thing I need to work out OR do I need a custom post processor?
I have a video on the Centroid Acorn forum here, (bottom of the page) please note the job it's running has a groving operation and cut off in the video. Notice how it starts at the bottom of the cut.
https://centroidcncforum.com/viewtopic.php?f=60&t=6345&start=50
