Tool path will not generate with tool orientation set to top approach.
- Mute
- Permalink
- Report
Hi all,
I am new to CNC lathe work but have lots of experience with CNC mill. I'm creating my 1st few programs in Fusion for cutting on my Sherline Chucker lathe which is a gang tool lathe. With my current set up which will be a default set of tools I have my cut-off tool at the top of the gang tool table coming in from the top. in the picture, it is tool #9 at the very top. I am trying to figure out how to resolve an issue regarding the cut-off operation. The tool path will not generate because I have the tool orientation set to the tooltip coming in from the top. Ive changed every setting I can but no resolve. Including edge to base the cut on, tool tip side etc. When I change tool orientation to the standard from the bottom approach it generates the tool path fine.
IS there a special setup or considerations for gang tool lathe setup and tools coming from both front and back?
Here is the file
