Post editing with Visual Studio Code
andrew.todd1
Message 1 of 12
andrew.todd1
Morning all.
Im have been diving into post editing with studio code.
See screenshot. Im editing a generic doosan milling post. the post has 5 axis capability but when i try and edit a 3 & 2 toolpath in studio code im getting this.
What am i doing wrong?
Replies (11)
Message 2 of 12
seth.madore
Hmm. Are you working with a sample part you can share? 5 axis Doosan should "just" be setting "has5axis" to "true" and you should be good to go.
Seth Madore
Message 3 of 12
andrew.todd1
Sure.
Both files attached.
Thanks.
Message 4 of 12
seth.madore
Using the stock post (not yours), I get code:
(FACE)
N10
T1 M06
(12 FLAT ENDMILL)
S7639 M03
G54
G00 A0. C0.
G00 X2.275 Y-1.882
G43 Z8.4744 H01
M08
G00 Z8.0744
And the whole program gets posted out. Using your post, I get the same. The trick is to change this:
Oddly enough, when I also set it to "no", I still get a program......
Seth Madore
Message 5 of 12
andrew.todd1
thanks for your help on this Seth
Message 6 of 12
andrew.todd1
also, can you tell me how i can add custom test that would appear at the start of every program?
Like after the program num (PROGRAM IS UNPROVEN, PROCEED WITH CAUTION)
Is this doable?
Message 7 of 12
seth.madore
This is what I have in my own posts, located right before the switch (unit) { line
  writeComment("SEE SETUP SHEET");
writeln("(LAST RUN)(UNPROVEN)");
writeComment("PROGRAM BY=STM")
writeComment((now.getMonth()+1) + "/" + now.getDate() + "/" + now.getFullYear() + " " + now.getHours() + ":" + ('0'+now.getMinutes()).slice(-2));
Now, before you go and paste that exact line in, you're going to need to add a new variable:
// collected state
var sequenceNumber;
var currentWorkOffset;
var optionalSection = false;
var forceSpindleSpeed = false;
var activeMovements; // do not use by default
var currentFeedId;
var g68RotationMode = 0;
var angularProbingMode;
var now = new Date ();      <-------------
var wfo;
It's the "var now = new Date (); line. I just wanted to show you where it went in the variables.
Oh, and you'll likely need to add a few characters to your var permittedCommentChars list:
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-/*#:";
Seth Madore
Message 8 of 12
andrew.todd1
thanks. Where to add new variable Seth?
Message 9 of 12
seth.madore
Somewhere in the "// collected state" area (line 209). If it's before any other variable, don't forget your ";" at the end
Example with the Doosan post:
// collected state
var sequenceNumber;
var now = new Date ();      <--------------
var currentFeedId;
var subprograms = [];
var currentPattern = -1;
var firstPattern = false;
var currentSubprogram;
var lastSubprogram;
var definedPatterns = new Array();
var incrementalMode = false;
var saveShowSequenceNumbers;
var cycleSubprogramIsActive = false;
var patternIsActive = false;
var lastOperationComment = "";
var incrementalSubprogram;
var previousABC = new Vector(0, 0, 0);
var retracted = false; // specifies that the tool has been retracted to the safe plane
probeMultipleFeatures = true;
And then further down the post (line 460):
// absolute coordinates and feed per min
  writeBlock(/*gAbsIncModal.format(90),*/ gFeedModeModal.format(properties.useG95 ? 95 : 00),gFormat.format(17), gFormat.format(40), gFormat.format(80), gFormat.format(90), gFormat.format(94),gFormat.format(98));
Resulting code (note the date time format, doesn't reflect the missing charcters mentioned above)
G00 G17 G40 G80 G90 G94 G98
(SEE SETUP SHEET)
(PROGRAM BY=STM)
(12312020 825)
Seth Madore
Message 10 of 12
andrew.todd1
Almost there Seth and thanks so much for the help.
One more thing bugging me. See attached screenshot. tis is from my customers original G code.
at the start of every toolpath we have this G68.2 line.
What is it and how can we replicate it on the post?
Message 11 of 12
seth.madore
Sorry Andrew, this last question is above my skill level to answer. I will point you to THIS THREAD where they explore adding Euler angles to a Mazak post.
Seth Madore
Message 12 of 12
andrew.todd1
Thanks Seth
