GCode repeat or loop
I have a laguna CNC with Rich Auto controller. I am trying to run an extremely simple operation, but have my file repeat or loop, to infinity or more likely until I hit the power button.
I want to use my machine to cut a chevron flooring pattern. Say my piece of flooring is 3/4" x 4" and all I want to cut is a miter on both ends. Ideally I would set up several cutting "jigs" around my table, and I would simply follow the machine around swapping out cut pieces for uncut pieces while the gantry and spindle are cutting in another location. After 3 or 4 cutting stations it would simply come back to the beginning and loop the cycle until I turn it off.
Is this A. possible to program within fusion, or B. something I can simply add to my gcode? I have tried a GOTON10 to try to get it to return to the beginning, replaced my m30 line with m99 etc. but most of these changes just produce an error.
thank you!
