Possible Bug with Morphed Spiral Multiple passes
jim
Message 1 of 11
jim
I am machining a surface using Morphed Spiral.  I want to do multiple down passes; however the path seems to be generated incorrectly.
The first operation of both OutsideIn and InsideOut is a plunge to final depth.  (This would be very bad in a hard material)
When OutsideIn is selected the cutter goes to the final depth and the StepDown steps go up from the final surface.
When InsideOut is selected the cutter cuts a track in the middle at the final depth and then goes up and works its way down.
Screencast URL.... https://autode.sk/2VeaCxr     (couldn't insert it because it says it's not published yet)
Jim
Replies (10)
Message 2 of 11
paolo.bastianelli
Hi @jim , I'm not sure this is a bug. Could you please send me the f3d file in private, so I can look at it? My email is paolo DOT bastianelli AT autodesk DOT com.
Paolo
Paolo Bastianelli
Technical Consultant
Message 3 of 11
jim
Sent the file.  Shouldn't step down go down, since it is supposed to remove material in multiple levels?  (Also the reason I don't think the plunge to final depth at the beginning is right, probably should plunge to depth of that layer.)
Message 4 of 11
paolo.bastianelli
Hi @jim I didn't get your email, could you please try sending it again?
Also, did you play around with different combinations of the "Axial Offset Passes"  and "Order by depth" check-boxes ? I'm guessing the reason for the tool stepping up is the way Fusion sees the model and tries to create a Spiral toolpath on it without being constrained to machining upwards/downwards but only out->in or viceversa.
Please let me know if you get anywhere with this and try send the project again 🙂
Paolo
Paolo Bastianelli
Message 5 of 11
jim
I've attached the file here to make it easier.
Order by depth didn't have any effect.  It looks like the initial move on an Inside Out is not a plunge but multiple circles to the final depth.  This still isn't really a desired effect, since we really want to remove the material layer by layer to avoid having the tool holder hit anything or run out of cutting surface.
Message 6 of 11
johnswetz1982
If you want to remove material layer by layer, why dont you use 3D adaptive then finish with morphed spiral?
Message 7 of 11
jim
That does work; however it's actually pretty inefficient with this shape.  (You can see it in the CAM process above)
The main reason I was using it was because I had changed the offset and shape a little and was modifying the part.  It already was much closer to its final shape than to the stock material.
Multiple layers of the morphing spiral would take the surface down extremely quickly.  This would allow me to run the last two processes (minus the drilling since the holes were pre-drilled and used to mount the material)
Obviously, there are multiple applications where you may want to use the spiral to clear material.
Message 8 of 11
paolo.bastianelli
Okay @jim , I took a look at your project and have passed this on to our development team for investigation. Whilst I can understand this is not desirable behavior,  let's wait and see what is causing it 🙂
Paolo
Paolo Bastianelli
Message 9 of 11
jim
OK sounds good.  How long do you think it will take to hear back?
Message 10 of 11
paolo.bastianelli
Hi @jim ,
Our development team are now actively looking at this, so we should hopefully get a fix at some point soon.
Thanks for reporting this issue, we appreciate your feedback 🙂
Cheers,
Paolo
Paolo Bastianelli
Message 11 of 11
jim
Sounds good. I look forward to a resolution.
Cheers,
Jim
