Message 1 of 11
Possible Bug with Morphed Spiral Multiple passes
- Mute
- Permalink
- Report
I am machining a surface using Morphed Spiral. I want to do multiple down passes; however the path seems to be generated incorrectly.
The first operation of both OutsideIn and InsideOut is a plunge to final depth. (This would be very bad in a hard material)
When OutsideIn is selected the cutter goes to the final depth and the StepDown steps go up from the final surface.
When InsideOut is selected the cutter cuts a track in the middle at the final depth and then goes up and works its way down.
Screencast URL.... https://autode.sk/2VeaCxr (couldn't insert it because it says it's not published yet)
Jim
