- Mute
- Permalink
- Report
Hello
I have attached a model, and a screen cast. The screen cast shows a simulation of a "dog bone" shaped channel being cut. The straight walls of the channel are cutting just fine , but the ears of the dog bone are not fully cutting. We measured the issue on our CMM, and you can see the weird behavior in the simulation.
We are using a long 3mm endmill, and the width of the ears is .125 The endmill should cut the ears with no problem, but it is not. I have been playing with the passes, and linking parameters to no avail. ??
Thanks for having a look.
Forrest
