Internal wrap for 4th axis part
CHAY.HOBSON
Message 1 of 25
CHAY.HOBSON
I am trying to create a toolpath that will mill the internal semi circle on the bike stem part. I can do it with the part stationary using a parallel or scallop but I want the 4th axis to rotate as well as the tool moving. When I try and use a 2d path and wrap it tries to wrap the outside of the cylinder and machine from the wrong side.
Any help would be greatly appreciated
I'm using a HAAS VF1 with a HRT160 4th axis fitted with a 5th axis vice
Replies (24)
Message 2 of 25
seth.madore
Nope, not possible at this point in time, unfortunately. It's been asked for before, but as of yet, it's not something that's available.
Seth Madore
Message 3 of 25
CHAY.HOBSON
Thanks Seth! It seems like the easiest and most useful thing! I'll stick to the ball tool from 6 separate angles.
Message 4 of 25
jswickJ9PWC
Have you tried using Flow with the "multi-axis" capability engaged? I've had good luck with that getting 4 axis toolpaths to do what you want (at least what I think you want.)
Message 5 of 25
CHAY.HOBSON
Looks like it works! I'll try it on the machine. Thank you!
Message 6 of 25
seth.madore
Well darnit, totally forgot about the 4th axis limit in Flow
/facepalm
Seth Madore
Message 7 of 25
CHAY.HOBSON
Everyday's a school day! 😀
Message 8 of 25
seth.madore
Hmm. 4th axis limit turned on gives me really poor results, and turning it off yields very small B axis moves. What results did you get, and what settings did you use?
Seth Madore
Message 9 of 25
CHAY.HOBSON
I have attached the file here. It won't let me post process as the direction is not supported!
Message 10 of 25
CHAY.HOBSON
 with BetaMode turned on I have no option to restrict to 4 axis in the flow toolpath. Even though the path I've created remains 4 axis it won't let me export to HAAS pre NGC 4th axis as the it thinks the toolpath is 5 axis.
Message 11 of 25
seth.madore
That's because it is a 5 axis toolpath. The option for 4 axis limiting shows up on the Geometry tab of the toolpath (no clue why they put that there)
Seth Madore
Message 12 of 25
CHAY.HOBSON
I don not have the option to restrict to 4 axis.
Message 13 of 25
seth.madore
It's in Preferences:
Seth Madore
Message 14 of 25
jswickJ9PWC
Turn it on in your preferences under "preview features"
Message 15 of 25
seth.madore
Alright, I chatted with one of the developers and found the solution (regarding why I was getting crappy results in 4 axis).
You need to set Tool Orientation like this:
 Sample file is attached
Seth Madore
Message 16 of 25
CHAY.HOBSON
Thank you for all your help and patience! I am now 95% there. Just one last issue. It seems no matter what I try it cuts the toolpath short (as in doesn't climb to the top of both sides) I've tried creating a new toolpath from scratch but it does the same...
Message 17 of 25
CHAY.HOBSON
I changed my set up WCS to the centre of part and it's all good now in simulation. It still won't let me post process the code.
Message 18 of 25
CHAY.HOBSON
I've done everything the same and it just won't let me output the code. I've even gone back and orientated the model the same as yours. I've put my file here. I would be grateful if you get a chance to have a look at it.
Message 19 of 25
seth.madore
What post processor are you using?
Seth Madore
Message 20 of 25
CRANDALLPRECISION
My haas a axis pre ngc posts the 4axis limit path
